E Studio 1105 J027 jams
  • Bicyclerepairman
    • 63
    Anyone seen duplex inverter jams on this model? Paper stops in inverter, rollers not driving. Not a connection issue, duplex works on different machine. Can not run inverter motor from output mode, thinking of IOB board.
    Last edited by Bicyclerepairman; 05-19-2015, 04:53 AM. Reason: want to make it a question
  • Bicyclerepairman
    • 63
    Re: E Studio 1105 J027 jams
    Replacing IOB fixed this.
      • 37488
      Check that gate solenoid is not binding on the linkage pin. Also check the mylar guides on the plastic guide plate. I have also had ribs get worn to the point of snagging the lead edge.
