6530C CE40 code
  • tnrtt
    • 156
    6530C CE40 code
    Switched to black and white in middle of color run then threw the code. Color has disappeared, black is fine.
    05=390 all colors above 268. 04-270 test patterns are all blank. 08-573 to 576 0 except 575 cyan at 7. Swapped entire EPU and transfer belt assembly, no effect. Drum and dev units turning. Put a strip of tape on M charge corona, blank. Didn't try laser or logic PCB. Anybody else see this?
    • 23009
    Re: 6530C CE40 code
    It sounds like you covered much of the logical choices. What's left? HVT, laser, LGC.
    I would expect the laser to code, so I would start with the HVT or LGC. =^..^=
