E-studio 255 MFP inactive all function other than copier
  • dharsha
    • Jul 2025
    [Misc] E-studio 255 MFP inactive all function other than copier
    I need big help from well known technicians, 255 MFP firmware updated, After that Scan, E-Filing, Print, Fax buttons are not working. When press that buttons beep sound hear, but function or function light not working. Can you help on this error.....?
    • 23006
    Re: E-studio 255 MFP inactive all function other than copier
    What sort of a display do you get? Any errors? Can you print off a 9S-107 or 9S-103 report? What errors are recorded? =^..^=
    • didi2005
      • May 2011
      • 401
      Fyi, there are 2 firmware for this model, based on the sticker colour on the scanner…red is 3 CCD, whereby yellow is 4 CCD…Make sure u upgrade the correct 1…
        • 23006
        If I remember correctly the MFP will become unhappy if you try to load the wrong firmware, but in the end it won't let you. =^..^=
