I have a Toshiba e-Studio 452 (page count 400k) that makes a clunking noise. I have isolated it to the tray 1 lift mechanism. The noise occurs if the tray is half full or so. It doesn't occur if the tray is nearly empty (light load) or if it's full (not much movement). It's not the tray itself. After swapping trays the noise still comes from the tray 1 position. What is the most likely cause? Sounds like a gear missing a tooth but so far I don't see it. Could it be the lift motor case, or would that affect all trays?
I've gotten around the problem for now by setting tray 1 to size A4 so it never gets selected, and leaving it almost empty. (I mostly work on HP and Canon, this is the only Toshiba machine I service).
