4520c Print Issue
  • Ron91
    • Sep 2013
    • 7
    4520c Print Issue
    Hi all,
    I seem to have an issue with printing paper 200gsm, previously i have had no issues and the print quality was perfect.
    But recently when I print on anything above 80gsm the ink does not stick to the paper, I have posted a picture of the output below:
    The ink seems to dry in little textured clumps, does it seem like fuser replacement is required?
    Thanks in advance
    Ron
  • didi2005
    • May 2011
    • 401
    Re: 4520c Print Issue
    Originally posted by Ron91
    Hi all,
    [ATTACH=CONFIG]30020[/ATTACH]
    Thanks in advance
    Ron
    U need to use thick paper settings according to your paper, this is due to thicker paper require more heat otherwise toners will not stick on the paper...
    • Ron91
      • Sep 2013
      • 7
      Thank you so much, this solution worked for me.
      For anyone else who is printing from windows image viewer, on the top you can select the paper type I used thick 2 and it worked perfectly for me.
      You can also select a specific tray by using the options link near the bottom of the window, than printer properties and select print feed.
