xerox pro 35 altboot problem
  • Tinochka
    • Jul 2012
    • 127
    I don't have a pissibility to reinstall software on network kontroller via altboot.
    I see on the screen:
    Xerox LynxOS Preboot 3.0.1 build 110298-G created Mon Jul 15 22:44:26 EDT 2002
    Copyright (C) 1987-1997 Lynx Real-Time Systems, Inc.
    IDE drive found!
    Usage:
    To Default Boot from SCSI/IDE Drive 0, Partition B (will default boot in 10 sec)
    Enter
    To ALT Boot from SCSI/IDE Drive 0, Partition A (for sec image loading)
    A
    Command? <b h0b /lynx.os>A
    ALT-Booting from SCSI/IDE Drive 0, Partition A!
    Loading... /lynx.os not found
    Error loading from /lynx.os, device h0a
    Command?
    Сan anyone help?
  • Tinochka
    • Jul 2012
    • 127
    Re: xerox pro 35 altboot problem
    • adriansto
      • 2388
      You must use Altboot for software reloading.
      • Tinochka
        • Jul 2012
        • 127
        Thanks, I know this.
        But I do not see the text which says "Press any key ...." and then I could reinstall software. When the controller begins boot up, I see in the altboot window only the text that is specified in the first message.
        This is the Problem.
        • adriansto
          • 2388
          Remove hdd, check memories and try again
          Sent from my V3-E
          • Tinochka
            • Jul 2012
            • 127
            I tried removing the hdd and checked the memory. The memory is working properly.
            The controller is loaded and writes "system is operational", but I don't have the ability to reinstall the software.
            Not appears the following text:
            ALTERNATE BOOT Ver 4.0
            System ID => Xerox Denali v1.00
            Bios ID
            => American Megatrends Inc. 0704 05/20/2005
            Board ID
            => Celestica Denali P2 CMYI32533011031
            uP ID
            => AMD mobile AMD Duron(tm) 01000 MHz
            Main Revision
            => 4.1.2
            Press Any Key For AltBoot Menu (05) 04) 03) 02) :
            • adriansto
              • 2388
              Check bios battery, remove battery for 20 -30 min then try altboot without hdd.
              Bad hdd block the system to boot.
              Are you sure the version of altboot you use is the proper version for wc35 ?
              • Tinochka
                • Jul 2012
                • 127
                bios battery - 2.92V
                I remove'd battery for 20 -30 min then turn on controller without hdd, but altboot show nothing.
                altboot version 5.2 for CC35-WCP55F
