Xerox wc 5765
  • Mukasa
    • May 2015
    • 178
    Xerox wc 5765
    Guy , i restored NVM for 5735-5790 on customer machine and the machine has changed the machine speed ID to 33 and the machine is asking for the change of fuser and xerographic modules.
    when i try to change the speed back to 65 its asking for xerox passcode which i need someone to help me with to close this call.
    Mukasa
  • adriansto
    • 2384
    Re: Xerox wc 5765
    You used wrong nvm file.
    Use the correct nvm file for 5765
    • Mukasa
      • May 2015
      • 178
      Re: Xerox wc 5765
      True but i don't have the NVM for 5765 . if you have it please can you send it to my mail .
      (mukasa_godfrey@yahoo.co.uk)
      • mkdirs
        • Oct 2014
        • 177
        Re: Xerox wc 5765
        check your pm
        Xerotk.com
        xerox copier technician
        • Mukasa
          • May 2015
          • 178
          Re: Xerox wc 5765
          Originally posted by mkdirs
          check your pm
          Thanks very much am going to download it.
          What machine serial number will i use?
          Mukasa
          • mkdirs
            • Oct 2014
            • 177
            Re: Xerox wc 5765
            Mukasa
            you do not need any serial number just load it then change to the right serial from the diagnostic mode
            Xerotk.com
            • Mukasa
              • May 2015
              • 178
              Re: Xerox wc 5765
              Thanks , after installing the NVB files still the Machine speed ID error has not cleared and the machine indentifer has remained as 151 and the machine speed still 33. yes i can change the machine serial no to the original through Diagnostics but still the machine is still down. when i try to change any of the above i need to put a password.
              mukasa
              • mkdirs
                • Oct 2014
                • 177
                Re: Xerox wc 5765
                Try to take out the NVM battery for a 5 minutes
                then redownload the firmware
                Did you find pws for 57xx ??
                Xerotk.com
                • Mukasa
                  • May 2015
                  • 178
                  Re: Xerox wc 5765
                  hello , yes i removed it for 5 min then i installed only NVM, what i did do is to reload the firmware.
                  let me do it i will get back to you.
                  I have the Xerox pws with 5735-5790 service manaul.
                  • nilak
                    • Aug 2010
                    • 72
                    Re: Xerox wc 5765
                    if you have a Eureka check the tip number 907532..
                    • Mukasa
                      • May 2015
                      • 178
                      Re: Xerox wc 5765
                      Hi Every one,
                      Thanks for your support i managed to fix the machine its now working.
                      Mukasa
                      • mkdirs
                        • Oct 2014
                        • 177
                        Re: Xerox wc 5765
                        could you told us how did you solved the problem
                        thanks
                        Xerotk.com
                        • rrk1366
                          • Aug 2015
                          • 7
                          Re: Xerox wc 5765
                          check your pm
                          • Lijodamodaran
                            service manager
                            • Sep 2014
                            • 56
                            Re: Xerox wc 5765
                            Hi Every one,
                            Mukasa
                            Sir could you please tell how you fix that issue ...my mail id lijodamodaran@gmail.com....thank you
                            • Mukasa
                              • May 2015
                              • 178
                              Re: Xerox wc 5765
                              hello , can you tell what is the problem with your machine.
                              Mukasa
