Xerox 3550
+ More Options
Posts
  • tcypy1961
    • 773
    Xerox 3550
    What would cause this copier to continuously make blank copies? Thank you for any help given.
  • mkdirs
    • Oct 2014
    • 177
    Re: Xerox 3550
    I think power supply
    Xerotk.com
    xerox copier technician
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      Re: Xerox 3550
      Try a different cartdritge the chip is corrupt (might be)
      My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
      • Exok
        • Jun 2011
        • 750
        Re: Xerox 3550
        Does it make blank copies even when you are not trying to make copies? If so your solenoids might be stuck open. The paper feed and registration clutch solenoids have rubber pads on them to keep the plate from making noise when they open and close but over time they rubber pads get sticky and cause the plate to get stuck open or stuck closed. You can remove the pads or what I do is cover the pad with a small piece of tape to keep it from sticking to the plate.
