Tried swapping ibt belt, 2nd btr, transfer belt cleaner and 1st bar's. Also replugged all plugs and flat cables on mcu and swapped out ibt motor. Any ideas?
550 error 42-324
Re: 550 error 42-324
Try to enter the component code [042-015 IBT drive motor]
Also take the IBT assembly out and make sure it rotates freely. The IBT cleaning assembly can sometimes cause it to bind, resulting in various 042-xxx codes.
Furthermore, Second BTR if not functioning correctly, will prevent the IBT from rotating as it should.
PM me if you think you need a MCU I have several I could sell you, as long as you're in the US.Comment
