550 error 42-324
  • MrXerox
    • Sep 2010
    • 76
    550 error 42-324
    Tried swapping ibt belt, 2nd btr, transfer belt cleaner and 1st bar's. Also replugged all plugs and flat cables on mcu and swapped out ibt motor. Any ideas?
  • adriansto
    • 2387
    Re: 550 error 42-324
    Check again 2nd BTR and ibt clwaner assy.
    If it's ok replace mcu pwb.
    • MrXerox
      • Sep 2010
      • 76
      Replace bit cleaner and 2nd btr with new ones, same error with jam stopping just past 2nd btr!! Any ideas?
      • InterfaceP
        • Jun 2013
        • 488
        Try to enter the component code [042-015 IBT drive motor]
        Also take the IBT assembly out and make sure it rotates freely. The IBT cleaning assembly can sometimes cause it to bind, resulting in various 042-xxx codes.
        Furthermore, Second BTR if not functioning correctly, will prevent the IBT from rotating as it should.
        PM me if you think you need a MCU I have several I could sell you, as long as you're in the US.
        • mickey singh
          • May 2014
          • 93
          Motor on ibt assembly not working, as above, run in diagnostics and check!
