Advice please - DC242
  • steveclv
    • May 2014
    • 95
    [CQ] Advice please - DC242
    From the attached scan of a print you can see vertical lines and poor quality print. Changed the drums and put in a new IBT Cleaner but they persist. I have new 1st BTR rollers to put in - could these be the problem or could it be something else?
    DC242 - approx 650,000 copies. Full toners.
  • adriansto
    • 2384
    Re: Advice please - DC242
    Check how the image looks directly on the belt.
    If the image is error free on belt then take a look to the 2nd BTR.
    • steveclv
      • May 2014
      • 95
      What is the technique to view the image on the belt. I don't want to damage anything but I guess I have to stop it printing at some point.
      • Exok
        • Jun 2011
        • 750
        First thing I would do is to run test patterns in solid colors black, cyan, magenta and yellow at 30-50% fill to see if the problem is in 1,2,3 or all colors.
        • Exok
          • Jun 2011
          • 750
          If the problem is only seen in 1 or 2 colors, this may be caused by toner dusting on the laser unit windows above the drum units.
          • steveclv
            • May 2014
            • 95
            Thanks - I'll run some test patterns this morning.
            Does anyone know how to interrupt the print so I can check the image on the IBT belt??
            • Exok
              • Jun 2011
              • 750
              You open the front door just before the paper reaches the 2nd BTR. You will have to do it a few times to judge the timing. Either that or place a piece of tape in the paper path before the 2nd BTR to cause a jam.
              • mickey singh
                • May 2014
                • 93
                Looks drum related!
