xerox 550 change rip
  • croma
    • Oct 2014
    • 87
    I have a 550 with integrated color server, I can replace it with a fiery rip? I saw that the rip Xerox EX Print Server is identical to rip exp260 ... is the same?
  • xcopytech
    • Aug 2006
    • 1794
    Re: xerox 550 change rip
    You need to install vsel pwb if you want to connect fiery on c550.
    You can not use ex260 fiery.
    • croma
      • Oct 2014
      • 87
      it's the same of 250?
      • xcopytech
        • Aug 2006
        • 1794
        Yes. Same for exp250.
        • adriansto
          • 2388
          You cant use the Fiery from a Xerox machine type to another machine type.
          You need to find Fiery designated for XC550 machine.
          • croma
            • Oct 2014
            • 87
            I have the 250 that I use for parts, I can take the pvs and mount it on the 550, I asked the rip because the "fiery EX server" for the 550 is identical to the EXP260
            • xcopytech
              • Aug 2006
              • 1794
              You can not use any pwb from dc250 on xerox c550.
              • croma
                • Oct 2014
                • 87
                damn, I tried to look on the internet but it is difficult to find the piece
                • xcopytech
                  • Aug 2006
                  • 1794
                  When you order a fiery from xerox you will get a vsel pwb, fiery and a cable.
                  Even if you find vsel pwb you will need fiery.
                  • croma
                    • Oct 2014
                    • 87
                    I have two 550, one with and one without the fiery, wanted to do a bit of testing before buying the rip and i wanted to buy a used rip ...
                    • croma
                      • Oct 2014
                      • 87
                      960K54021 - Xerox Printer Processors and Circuit Boards
                      what the difference between 960K54021 and 960K54020?
                      • xcopytech
                        • Aug 2006
                        • 1794
                        There is no difference between these two part numbers.
                        960K54021 is newer and maybe have some modification, but you can use both of them.
