Hi guys,
I have a Xerox WC 5675 machine that i dismantled the insides for overhaul cleaning. When i put back everything and tried, it is giving me a jam on the side and the paper won't go thru. If i look at the Fault, it is giving 09-350. Can someone guide me as to what is causing this? I did not remove any connections at the back of the machine, just the assemblies inside when you open the front door.
Thank you
Thank you
