Xerox WorkCentre 7755 error 342-325 (342.325.00) Main Motor Failure
  • Detonation
    • Feb 2010
    • 410
    I have a Xerox WorkCentre 7755 that is giving error 342-325. According to service documentation this is a Main Motor Failure. The procedure is:
    1. Run Component control 042-002 Main Motor. => Main motor runs without issue
    2. Check waste toner collection path for bent pipes etc. => Path looks ok, changed the main pipe and the waste container just to be sure, without result
    3. Check black drum cartridge. => Replaced with new one, same problem
    4. Replace Main Motor. => Replaced, same problem
    5. Replace MCU PWB. => Replaced, same problem
    I checked connections (flat cables) between MCU PWB and LVPS, and they look alright. No corrosion of any sort. I'm not sure what to do next. Any suggestions would be very welcome!
  • adriansto
    • 2388
    Re: Xerox WorkCentre 7755 error 342-325 (342.325.00) Main Motor Failure
    Front door interlock switch.
    • Detonation
      • Feb 2010
      • 410
      Thanks, will try that first thing monday.
      • Detonation
        • Feb 2010
        • 410
        Front door interlock switch changed for new one, same error...
        • Detonation
          • Feb 2010
          • 410
          I am really stuck on this and would enormously appreciate input. Anyone?
          • adriansto
            • 2388
            While you run the main mot in component control mode do a voltage measurement of 24 volts source in several points.
            • mickey singh
              • May 2014
              • 93
              Swap ribbon cables around on mcu to see if you get same fault, could also be power supply or iot driver
              • xcopytech
                • Aug 2006
                • 1794
                Did you check black developer assy?
                • Detonation
                  • Feb 2010
                  • 410
                  Thanks guys, I can/will check into this next monday. I haven't tried swapping power supplies and/or flat cables yet. As for the developer assy, I can try to swap that as well of course - but shouldn't that generatie a developer drive error?
                  • xcopytech
                    • Aug 2006
                    • 1794
                    Main motor drive also drive black developer assy and 2nd btr.
                    So check black developer assy and 2nd btr.
                    • Detonation
                      • Feb 2010
                      • 410
                      Thanks, I will check and post back monday.
                      • Detonation
                        • Feb 2010
                        • 410
                        xcopytech had the right solution, the black developer was jammed. Replaced with new and all is good now. Thanks everyone for the input!
                        • Bessnet
                          • May 2016
                          • 5
                          Hello Guys,
                          Please help me in regards with above mentioned error codes first code is 342-325 then 394-322.
                          main motor is not rotation and machines is not rotating as usual, at starting bypas lifts up half and ibt unit lifts and stuck in half.
                          i have tried changing
                          1. main motor assembly.
                          2. black drum motor assembly.
                          3. black developer motor assembly.
                          4. waste toner assembly.
                          5. 2nd btr drawer complete assembly
                          6. all drum motor.
                          7. mcu pwb board
                          • rockdude
                            • Feb 2011
                            • 257
                            Please re-read what "Xcopytech" said.
                            Check the "imaging units" or "Developers Drums" whatever you want to call them, and check for Frozen, Stuck, binding, etc.. and replace whatever ones are bad.
                            These are "consumables" !!
                            • Bessnet
                              • May 2016
                              • 5
                              I have a running machines xerox dc 252 with me so I have tried changed all four drums and four developer units from a running machines.
                              same problem Ibt unit and bypass tray lifts up half and then struck
                              machines is idle no sounds on any assembly (motor ) rotation
