wc5790 mistakenly loaded firmware
  • White_Toner
    • Aug 2009
    • 71
    [Dead] wc5790 mistakenly loaded firmware
    I have wc5790 with 61.131.221.10401
    don't ask why (machine was in good condition)., but mistakenly was loaded firmware
    61.130.000.04205 from usb flash.
    As result "printing and copying unavailable"
    Machine doesn't see any tray and finisher.
    Altboot - the same. Altboot whith 61.131.221.10401 - no change.
    When download progress in forsed - everything stops on "copy/printing engine controller"
    All voltage on IOT are in OK.
    CR29 on IOT lit (need flash) CR29 not lit (need flash)
    looking at the symptoms i need replace IOT. Who can explane me
    how IOT was killed. May be there is any way to to revive IOT?
  • White_Toner
    • Aug 2009
    • 71
    Re: wc5790 mistakenly loaded firmware
    5790 whith tag 155
    • adriansto
      • 2387
      Originally posted by White_Toner
      5790 whith tag 155
      You can try altboot with upper level software version
      • White_Toner
        • Aug 2009
        • 71
        to adriansto:
        AT last attempt it was 061.132.226.02000
        • adriansto
          • 2387
          You was using too high version.
          061.132.221.21403 is the software level for new tag155 iot.
          First do a simply altboot with this software version and after that do a forced altboot with same software version.
          • mntech
            • Aug 2010
            • 250
            adriansto,
            I need some help with something but your private message storage is full, can you please contact me.
            Also my apologies for unrelated post.
            Thanks,
            mntech
            • adriansto
              • 2387
              Originally posted by mntech
              adriansto,
              Thanks,
              mntech
              stoadis@gmail.com
              • Zahid khan
                • May 2016
                • 72
                Sit altboot do nothing on my Xerox it would not update.xerox 5765. It does not boot.and now after removing the battery now on starting the screen remain green fore ever .ow could I fix it
                • adriansto
                  • 2387
                  I told you on email what you need to make.
