Check that and post the resulting 2 digit code. If no faults found, replace following parts in sequence: DARTS2 PWB > ESS PWB
Hello i am having same problem with my xerox c60. The steps mentioned here are too complicated for me to execute and understand them properly. Is there a step to step guide to go through this process ?
Any help will be greatly appreciated.
Kind Regards
Hameed
Hi,
had the same problem 715-030 done result display 1100 any information you can bring will be appreciated
Had an intermitten problem like this on a C60. When we looked into it, the connector from the doc feed to the back of the machine
was bent. After tearing it apart, you could see physical damage to the socket. Replaced the socket and the problem went away.
Thanks for the hint will check later then post results
