xerox 8830 quality
+ More Options
Posts
  • walidcharifi
    • Feb 2011
    • 379
    xerox 8830 quality
    hi freinds
    my problem is a print quality in xerox 8830
  • technogeek2009
    • Mar 2011
    • 167
    Re: xerox 8830 quality
    From the print sample, it looks like a blur running across the print from side to side. If this is in fact the case, the source of the problem depend whether this blur occurs near the lead or trail edge of the print. If lead edge, the most likely candidate is the fuser roller. If near the trail edge, then a cutter related problem is most likely.
    • walidcharifi
      • Feb 2011
      • 379
      thanks freind for reply
      see attachement page test
      • walidcharifi
        • Feb 2011
        • 379
        help me
        • tonerspot
          • Nov 2008
          • 79
          Check the exit rollers, clean, and you can put more presure on the spring of passive one.
          • xcopytech
            • Aug 2006
            • 1792
            Need more info about your problem.
            Is this blur near lead edge or trail edge.
            If it is near lead edge check pressure belt in fuser assy.
