Xerox 4110 fault code 077-311
  • Detonation
    • Feb 2010
    • 410
    [Error Code] Xerox 4110 fault code 077-311
    Xerox 4110 gives a error 077-311 which I cannot get rid of. So far I have replaced:
    - IOT PWB
    - MCU PWB
    - AC power supply
    - HVPS
    - entire duplex drawer
    - female connector (machine side) for duplex drawer
    When running 077-016 (inverter motor) in component control, the motor runs, but does not stop. Which it should (according to service manual) when the inverter sensor detects.
  • adriansto
    • 2388
    Re: Xerox 4110 fault code 077-311
    Check:
    machine 24 volts, front door interlock switch.
    voltage from LVPS finisher power supply 24 Volts.
    finisher left door interlock switch.
    • Detonation
      • Feb 2010
      • 410
      Thanks Adrian, it also gives the error with finisher disconnected. Is it front door interlock then?
      • adriansto
        • 2388
        Is it intermitent error or at start-up ?
        • Detonation
          • Feb 2010
          • 410
          Constantly at start-up.
          • adriansto
            • 2388
            Then check door interlock switch.
            You can make shortcircuit over the switch pins.
            • Detonation
              • Feb 2010
              • 410
              Replaced front door interlock switch, but same problem. Damnit
              • adriansto
                • 2388
                - IOT PWB
                - MCU PWB
                - AC power supply
                - HVPS
                Is the 24 volts tension ok ?
                Check the sensor of the inverter release motor pl14.6 nr.4
                Also remove the duple assy and check for bent pins in duplex connector.
                • Detonation
                  • Feb 2010
                  • 410
                  Have already replaced the entire tray... Where is the best point to measure 24 volts?
