colorqube 9303 lines only coping
  • acsolutions
    • Jun 2010
    • 519
    [CQ] colorqube 9303 lines only coping
    Hello, machine prints fine no issues. When coping, scanning or coping from feeder machine showing lines and will not color scan at all I'm going for the ccd but wanted your thoughts2016-07-13 13.40.33.jpg2016-07-13 13.40.33.jpg
  • Flash
    • 378
    Re: colorqube 9303 lines only coping
    Go for the ccd.
    • acsolutions
      • Jun 2010
      • 519
      Are there any adjustments that need to be performed after replacing the ccd?
      • jhalfhide
        • Apr 2015
        • 454
        Whilst you're at it, ensure you do the ribbon cable mod if you haven't done already.
        • acsolutions
          • Jun 2010
          • 519
          The narrow one that goes to the scanned? What's the mod?
          • jhalfhide
            • Apr 2015
            • 454
            The white thin one. As the scan carriage moves back and forth, the ribbon cable scrapes the metal plate with holes in. The edges of the holes are slightly sharp and after a while it wears through the ribbon cable enough to short and blow boards. Known problem. Put electrical tape over the metal plate so the cable doesn't rub.
            • acsolutions
              • Jun 2010
              • 519
              I replaced the scan cable and ccd, that fixed it!
              • acsolutions
                • Jun 2010
                • 519
                I'm working on a different machine and I did a jet direct text and I have a ydot position correction failure, what does that mean? The uniform between printheads are different on one only!
                • Flash
                  • 378
                  Are you getting any fault codes?
                  • acsolutions
                    • Jun 2010
                    • 519
                    No, I'm getting a finisher cod saying finisher main tray out of service check for obstruction in the main tray. What is the main tray, is that the delivery tray?
                    • jhalfhide
                      • Apr 2015
                      • 454
                      The motors on the big finishers have issues. Known problem. Could be that. Could also be the ejector assy/fingers. What's the finisher code?
                      • acsolutions
                        • Jun 2010
                        • 519
                        I didn't see a code.just that message. I had someone mention the cat5 connector on the lower tray. Sorry I'm new on this machine I had a bunch recently thrown at me! Doesn't it usually show the code on the top left of the screen? I didn't look in the Service mode, I guess that would be under diagnostics! Are there any particular codes that are the norm with this issue? Thanks again
                        • jhalfhide
                          • Apr 2015
                          • 454
                          Code is in service mode. Sometimes they show a code on the normal UI but going into service mode often shows the "true" code. When I'm in front of my laptop, I will look up the bulletin.
                          • acsolutions
                            • Jun 2010
                            • 519
                            Thanks, I'll go there tomorrow and investigate the code! Thanks for everything
                            • jhalfhide
                              • Apr 2015
                              • 454
                              Just had a look, quite a few eureka tips on the finisher problem. Best get on site and post the codes.
