I picked up a EXFiery System for the DCCS50 at my shop. I have a Cobra on it that works. The pws says how to connect the two big cables and when I do the EX12 will blue screen and the copier shows 'check network cables/connections'. The nvm is set for '2' under copier configuration (options 0-4). Any ideas?
I know it's really old. The only driver I've found is for XP and it doesn't always connect. Also, I can send it as a ps file through the browser (very limited). I want to use up all the toner and supplies before scrapping it.
Mike
Mike
