Pls help me on error 117-325, on Xerox 550 and CE is not coming up and the machine seems hanging?
Xerox 550
Tags: None
Re: Xerox 550
It is wonderful if you have a previously machine nvm's saving.
If so, try to restore it - dc351 and reload machine software.
If fault still exist after all, then you need to replace the ess nvm pwba module.Comment
Re: Xerox 550
Dont remove battery, it will kill the metered pin and reset to default, it also kills the software on the pwb, you will most likely have to purchase a new nvm pwbComment
Re: Xerox 550
Wat am I going to do cuz, i hav remove d battery and d time hav reset to 2050 and the error still remains and is not shut down again! Pls help me out!Comment
Re: Xerox 550
The software is still into this module flash memory but the chip device is bad.
The error 117-325 point to the fact the electronic chip device is malfunctioning.
If another error is pop-up on the screen this can be a good thing.Comment
Re: Xerox 550
If you have same 117-325 error then you need to replace the ess nvm module.
Re: Xerox 550
cuz the supplier meter of dis machine hav time out already.
Pls I will be glad if u can reply me now.....Comment
Re: Xerox 550
You need to restore some settings into ess nvm pwb.
You need to apply gp4 procedure as it is write into service manual
Do you have service manual for the machine ?Comment
