Xerox 550
  • Jibes_Tech
    • Aug 2016
    • 11
    [Error Code] Xerox 550
    Pls help me on error 117-325, on Xerox 550 and CE is not coming up and the machine seems hanging?
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox 550
    There is no 117-325 error.
    It could be 116-325.
    Ess fan error
    • Jake2o
      • Dec 2007
      • 325
      Re: Xerox 550
      Can you post a picture of the error on screen?
      Is it a black screen with red writing or the normal error screen with the error code in the corner?
      • adriansto
        • 2383
        Re: Xerox 550
        Remove battery from ess nvm pwba for 2 minutes. Put it back and try again.
        It is wonderful if you have a previously machine nvm's saving.
        If so, try to restore it - dc351 and reload machine software.
        If fault still exist after all, then you need to replace the ess nvm pwba module.
        • mickey singh
          • May 2014
          • 93
          Re: Xerox 550
          Dont remove battery, it will kill the metered pin and reset to default, it also kills the software on the pwb, you will most likely have to purchase a new nvm pwb
          • Jibes_Tech
            • Aug 2016
            • 11
            Re: Xerox 550
            Wat am I going to do cuz, i hav remove d battery and d time hav reset to 2050 and the error still remains and is not shut down again! Pls help me out!
            • mickey singh
              • May 2014
              • 93
              Re: Xerox 550
              Where abouts in london are you? Pm me your details and ill give you a call
              • adriansto
                • 2383
                Re: Xerox 550
                If you have same 117-325 error then you need to replace the ess nvm module.
                The software is still into this module flash memory but the chip device is bad.
                The error 117-325 point to the fact the electronic chip device is malfunctioning.
                If another error is pop-up on the screen this can be a good thing.
                • Jibes_Tech
                  • Aug 2016
                  • 11
                  Re: Xerox 550
                  I hav done dat, is showing error 124-315 pls Wat am I going to do next?
                  • adriansto
                    • 2383
                    Re: Xerox 550
                    You need to do the gp4 procedure -serial number syncronization- using sys1 as the pwb with good data.
                    After that restart machine and check for others errors.
                    • Jibes_Tech
                      • Aug 2016
                      • 11
                      Re: Xerox 550
                      You need to do the gp4 procedure -serial number syncronization- using sys1 as the pwb with good data.After that restart machine and check for others errors.
                      Good data? And wich serial number am I going to use?
                      • adriansto
                        • 2383
                        Re: Xerox 550
                        Read gp4 procedure from service manual
                        You will use the correct data from sys1 pwb as reference data for sys2
                        • Jibes_Tech
                          • Aug 2016
                          • 11
                          Re: Xerox 550
                          Do you hav any good data to help me with
                          cuz the supplier meter of dis machine hav time out already.
                          Pls I will be glad if u can reply me now.....
                          • adriansto
                            • 2383
                            Re: Xerox 550
                            We dont talk here about PagePack option.
                            You need to restore some settings into ess nvm pwb.
                            You need to apply gp4 procedure as it is write into service manual
                            Do you have service manual for the machine ?
                            • Jibes_Tech
                              • Aug 2016
                              • 11
                              Re: Xerox 550
                              We dont talk here about PagePack option.You need to restore some settings into ess nvm pwb.You need to apply gp4 procedure as it is write into service manualDo you have service manual for the machine ?
                              Noope I don't have!
