wc 7775 falult codes 347.310.00-377.909.00-342.326.00
  • Dayspringprint
    • Aug 2016
    • 6
    these three fault codes came up on my WC i have disconnected the finisher then i just receive the 342.326 error I try to reset software that did not work I have tried to reset belt position but when i press 0 and hold for 5 sec then press start I dont get any response except it says "you must be in service pathway to press start" can anyone help?
    thanks
  • InterfaceP
    • Jun 2013
    • 488
    Re: wc 7775 falult codes 347.310.00-377.909.00-342.326.00
    Try turning it off and back on with the front door open. Then try to enter CE mode
    • Dayspringprint
      • Aug 2016
      • 6
      Ok, sorry but the system does clear the error codes, but when i send print to it the system cycles up and then i get the error again 342.326 my belt long counter show 741-105 2 what else may be wrong
      unbelievable that worked thank you
      • Dayspringprint
        • Aug 2016
        • 6
        if the error keeps coming back everytime i try to print what else could I do ?
        • InterfaceP
          • Jun 2013
          • 488
          The sensors on the IBT assembly are likely dirty. Use some canned air to clean them. Hers an old Video I made years ago: https://youtu.be/nug0CbfX-no
          • Dayspringprint
            • Aug 2016
            • 6
            thanks I will give that a try. The video seems very helpful
            • Dayspringprint
              • Aug 2016
              • 6
              Hi there perhaps you could help me with one other thing- i have a finisher on this xerox 7775 prior to this error with the belt it gave me a communications error with the finisher so i disconnected the fisnisher are these two errors linked in any way if i reconnect the finisher will it cause a problem for the printer or is the communication error a sepertate issue- i would like to be able to use the finisher but not sure if it is a part or what that has gone bad thank you
              • InterfaceP
                • Jun 2013
                • 488
                Several things could be the problem. The most common would be the Finisher isn't properly connected or the connections are damaged. Other than that it's likely the Finisher PWB. Lastly the MCU on the 7775 is faulty.
