93-564 Error Code
  • acsolutions
    • Jun 2010
    • 519
    #16
    Re: 93-564 Error Code
    Originally posted by prismtech
    You need to purge on a new res.
    Check for blowout signs like this:
    These are all pics of what happens when heads leak after being reinstalled - used. All are now junk.
    The manuals said I don't need to purge it if I'm only going to replace the reservoir.
    I replaced the #4 print head because it was leaking on the lower head!
    Sent from my SM-J120W using Tapatalk
    With what I described to you does it sound like a reservoir issue? I added wax to the reservoir because it become low and still the same problem? I'm just going to replace the reservoir and go into dc976 and purge only the reservoir and that's it! Do you think I need anything else?
    • acsolutions
      • Jun 2010
      • 519
      #17
      .. the manual doesn't say anything about purging the reservoir if you're just replacing the reservoir. It just talks about doing the head-to-head adjustment
      • prismtech
        • May 2014
        • 199
        #18
        The option for reservoir ink fault recovery exists for a reason. You don't just bang in a new pot and fire it up.
