Xerox workcentre 7845 - Scan to folder
  • Dig
    • 14
    I have a 7845 that was working fine up until a week ago. We had it setup to scan to a particular computer folder. We called the folder scan. Actually as much as I hate to admit it I set it up but it was last year. For some reason it refuses to scan to the folder anymore. It just says failed.
    The template says it is scanning to 10.1.10.21 well the problem is I can't find any computer with that address. More crazy is if I ping that address I get a reply but I checked the computer it was scanning to and that is not the address.
    So can someone please help me. How to I setup a scan folder do the xerox will send it. Is it as simple as just changing the IP address in the template to reflect the address of the folder or are there other steps I can not remember?
    Thank you for your help in advance.
  • copier tech
    • 8132
    Re: Xerox workcentre 7845 - Scan to folder
    You would be better using the pc host name rather than the ip address as the pc is most likely on dhcp so will change the pc ip address. (The pc host name never changes)
    • Dig
      • 14
      Thanks for the quick reply.
      I tried as you suggested but it keeps saying it failed because there is a login failure. Check user password and or setups.
      Not sure what this means? I tried using the username and password of the machine but that did not work.
      Any help appreciated
      • acfife
        • May 2012
        • 63
        Setup a template in Scans tab
        Add New
        File Destination scans (for example)
        Friendly Name: scans (for example)
        Default Repository Protocol: SMB
        Hostname or IPv4 Address : Port 139 or 445
        Share: share name IE. Shared
        Doc Path: folder IE. scans
        Login name: Domain\Username (suggest creating user account for scanning - such as scanuser)
        Password: set never to expire/change
        Select Stored in template option
        If shown un tick save job log (.XST)
        Then Save/Add
        • Dig
          • 14
          Add New
          Then Save/Add
          Thanks for your help.
          I almost got it. The error now states Conflicting job setting invalid path
          Not sure what this means.
          If I use my PC I can see the server in my network and if I click on the server name I can see and access the folder named scans
          In the template under Document Path I typed in the following \\servername\scans
          But when I try to scan to this folder it gives me that error message
          Any ideas or help greatly appreciated
          • Dig
            • 14
            1. Originally posted by acfife
            Add New
            Then Save/Add
            Got it! Just took the info out of the destination folder and left it blank and it worked perfect.
            Thanks again
            • acfife
              • May 2012
              • 63
              Try setting up as below image, make sure there is only one "scans" folder and do not add the \\ or \ in path details.
