Xerox 6605 dn - 093-926
  • savi0r
    • Sep 2010
    • 363
    [Dead] Xerox 6605 dn - 093-926
    Hi guys. Can someone help me with this? The story is this : i ran out of toner on this printer. Took the black toner from another printer, refilled it and put it back in. Now it gives me error code 093-926. The thing is : i can print test pages in service mode. They come out perfectly. After some nvram reset, the printer goes ready, i can see that the black cartridge is 100% then it says processing ( the startup page) then it goes again in error 093-926. Any ideas? Tried with 2 different chips : for 3k and 8k. The same.
  • acfife
    • May 2012
    • 63
    Re: Xerox 6605 dn - 093-926
    From Xerox eureka tip - worth a try
    It has been reported that the firmware does not correctly report errors
    associated with toner cartridges. I am also assuming that the customer also
    changed the yellow toner at the same time as black based on the
    solution.
    Install a new yellow toner. Once you do that, wait a few seconds for all of
    the messages to reset. You should also see a Xerox Genguine Toner window pop up
    for a second.
