Error Xerox Nuvera 288
  • assvlad
    • Dec 2015
    • 17
    [Error Code] Error Xerox Nuvera 288
    Good day! The problem was discovered two months ago. The error window to replace weak batteries charge to NVM. The battery was changed to two boards NVM. The machine does not work. We ordered two boards NVM, we have changed. Nothing happened. Machine dead. Error PEM-22-3200, PEM-22-3155
  • xtrain
    • Dec 2012
    • 233
    Re: Error Xerox Nuvera 288
    PEM 22-3200 shows your system software license has expired, FFPS or DocuSp controller.
    • assvlad
      • Dec 2015
      • 17
      PEM-22-3200 System communication problem is being detected
      • xtrain
        • Dec 2012
        • 233
        Yes, the rap reads system communication problem, but if you read further, it states that the system software license has expired and is the cause of pem-22-3200.
        • assvlad
          • Dec 2015
          • 17
          License normal. The machine worked on her.
          • adriansto
            • 2388
            Be sure the internal ethernet cable is pluged in ERI_1 and the customer ethernet cable is pluged in ERI_0.
            Also watch CR33 and CR70 leds on registration control pwb. These must flicker. If they stays on then the distribution cable may be defective.
            I presume you have the machine service manual.
            • assvlad
              • Dec 2015
              • 17
              Hello. Ethernet cable checked. Good. CR33 and CR70 no LEDs on the Board. The service manual I not have.
              • assvlad
                • Dec 2015
                • 17
                20160802113831.jpg20160802113841.jpg20160802113851.jpgIMG_20160915_163906.jpgIMG_20160920_085355.jpg
                • adriansto
                  • 2388
                  Wihtout service manual the better ideea is to place a call to xerox service.
                  It is not a easy to service machine.
                  cr33 & 70 is on REGISTRATION CONTROL electronic board.
                  • assvlad
                    • Dec 2015
                    • 17
                    Without service manual it's hard to do something.
                    IMG_20160920_114451.jpgREGISTRATION CONTROL electronic board it? I'm only on this Board found rc70! For this Board are burning red Leds CR-81-36V, CR32-24V, CR17-RESET, CR21-TERMINA TED.
                    • adriansto
                      • 2388
                      Where are you from ?
                      cr33 & 70 dont lit = possibly firmware / software corruptioncr3370.jpg
                      • assvlad
                        • Dec 2015
                        • 17
                        City Stavropol, Russia.
                        NVM cards bought new (as advised by the service engineer). Software installed.
                        • adriansto
                          • 2388
                          Software was installed by service engineer ?
                          He is a xerox tech or all copiers tech ? He has the service manual ?
                          Are you sure you reload the licence string after loading software ?
                          Did you made a save of the config from machine ?
                          • assvlad
                            • Dec 2015
                            • 17
                            Software was installed by service engineer? Yes.
                            He is a xerox tech? Yes.
                            He has the service manual? Yes.
                            Are you sure you reload the licence string after loading software ? Yes. I have two licenses until 2017. One working, the other ordered the enter to the service mode.
                            Did you made a save of the config from machine ? No.
                            Print Modules 1 and 2 - Leds 33 and 70 do not burn.
                            • assvlad
                              • Dec 2015
                              • 17
                              cr33 & 70 dont lit = possibly firmware / software corruption[ATTACH=CONFIG]34181[/ATTACH]
                              Hello. My old Board NVM 960K73400, and send me a 960K25242. Put the old Board 960K73400 led indicators CR70, 33. Question? May not be suitable Board NVM to my car? Is it possible to recover my NVM?
