Colorqube 9301 Harddisk replace
  • kurbads
    • May 2017
    • 26
    #31
    Re: Colorqube 9301 Harddisk replace
    I started a new thread ColorQube 9303 pre-heater rolling pump
    • hagalis
      • Feb 2021
      • 2
      #32
      Originally posted by prismtech
      Google "spar xls" and go to the first result which is a hidden spreadsheet on Xerox's site. Find the latest Connectkey 1.5 version for the colorqube and download it. Place it in the Altboot folder in your usb stick along with the 0 byte FORCED_UPGRADE file. Plug in your 256GB platter drive and the usb stick and an hour later you are all done.
      If it doesn't work it's due to:
      USB stick not compatible. Recommend Kingston fat32 and usb 2.0 standard. USB 3.0 sticks are questionable on Altboots. on a 9200 colorqube usb 3.0 does not work at all.
      256GB platter drive is bad. Even one bad sector causes Altboot to never blowup the image.
      Ime or ui board failure. Very rare, most likely one of the first two problems mentioned.
      Correct your software load first and then I will help you fix your heater problem.
      Sent from my SM-T530NU using Tapatalk
      Hi prismtech, thank ou so much! Your advices helped so much. Got 2 9301 running with altboot and It also asks for supply code and offers a 4000 page courtesy period. How do I get rid of that?
      Is there a solution? Would appreciate, if there is one.
      Best ragards and thanks from Germany
      Andreas
      • kurbads
        • May 2017
        • 26
        #33
        Andreas
        You need American rom (NVRAM). Prismatech promised to send one but kept staling and never replied at the end.
        You can buy them for $20-30
        The reason is that the firmware you put on is US and there are no EU versions. So because you cannot bring Mohamed to mountain, you have to bring mountain to Mohamed.
        David
        • hagalis
          • Feb 2021
          • 2
          #34
          Originally posted by kurbads
          You need American rom. Prismatech promised to send one but kept staling and never replied at the end.
          David
          Hi David, thanks for your quick answer. and where can I buy American rom? Could you give me a hint or a link?
          But I have german language on it, so this is anyway no EU version?
          Did you solve the problem: It also asks for supply code and offers a 4000 page courtesy period. How do I get rid of that?
          If so, I would be happy to hear from you.
          Cheers Andreas
