Wc5665/5675 machine
  • andywong90
    • Mar 2013
    • 110
    Wc5665/5675 machine
    Hello fren, may I know Wc5665 got one diskette located at rear cover machine.what it use for?? I really need know use for what?who can tell me in detail,pls.thanks
  • Flash
    • 378
    Re: Wc5665/5675 machine
    It is used to restore NVM settings in the event they become corrupted.
    • andywong90
      • Mar 2013
      • 110
      Ic,thanks a lot.what come out or what happen to machine if nvm corrupted? Any code sign out?
      • andywong90
        • Mar 2013
        • 110
        One things temp I can't solve is wc5665 always appear system unavailable do not shut down until machine shut down
        .Sometime while turn on machine,pls wait self test in progress and then will restart.izit nvm corrupted or software problem? This problem make me crazy because can't solve.
        Anyone can tell me or share me what I need to do? Thanks
        • adriansto
          • 2387
          Reload machine nvm\s using diskette you have.
          • andywong90
            • Mar 2013
            • 110
            Ic.if that may I know how to reload machine nvm using disket ? Can tell me in detail? Usually I previous got try chg the yellow bateri ( software module ),but results is only temp,after 1-2week ago same problem machine will auto restart and system unavailable again.
            Machine nvm is save in where? Izit save in yellow bateri? Hope fren can tell me. Thank very much..
            • adriansto
              • 2387
              What is the machine software version and serial number ?
              You need to use pws diagnostic tool - nvm save an restore and restore the files from that diskette.
              • andywong90
                • Mar 2013
                • 110
                Ic.but that diskket I think lose o missing already.can use another disket to restore ?
                • andywong90
                  • Mar 2013
                  • 110
                  Can fren send me the pws diagnostic tool software? Thank.because I really no experience in this product.thanks a lot.
                  • adriansto
                    • 2387
                    stoadis@gmail.com
