WC7328 jamming at exit
  • axyun
    • Aug 2007
    • 1323
    Have jamming every time after paper exits fuser and is entering delivery assembly. The trailing
    edge of paper has not exited fuser and the front edge is just entering delivery unit. If I manually
    turn drive gear for delivery unit while trailing edge of paper still in fuser the paper does not
    advance but that is probably because to much resistance in fuser rollers holding paper back.
    When I turn drive gear manually with paper out of fuser the paper advances thru exit unit.
    I was able to see drive gear turning during copy cycle . I will look in Sm to check paper jam
    history for sensor actuated in meantime.
    I have swapped with new fuser and exit assembly but still have same issue. I cleaned
    2 photo sensors below fuser as well. I don't service this series often and would be very grateful for advice. Frank
  • xeroxsharp
    • Nov 2008
    • 270
    Re: WC7328 jamming at exit
    Take a good look at FUSSER EXIT SENSOR. Sensor is located at left door assy ( sensor actuator arm could be broken ).
    OR
    Bearings on BTR assy could be in bad shape.
    • axyun
      • Aug 2007
      • 1323
      Thank you for help. I have a Phaser 7760 l door asm which has same parts so I can test. Frank
      • livewire
        • Sep 2011
        • 608
        This is "morning jam"? Try to load paper with SEF.
        • axyun
          • Aug 2007
          • 1323
          Thanks Livewire but not morning jam. Jams every page all the time. Fuser exit sensor code 010-110.
          • xeroxsharp
            • Nov 2008
            • 270
            simplex or only duplex jam
            • axyun
              • Aug 2007
              • 1323
              simplex.
              • xeroxsharp
                • Nov 2008
                • 270
                Originally posted by axyun
                simplex.
                Do not know anymore.
                Sorry
                Regards
                • axyun
                  • Aug 2007
                  • 1323
                  I ordered fuser exit switch. I will post results when complete. Thank you. Frank
                  • axyun
                    • Aug 2007
                    • 1323
                    sorry. i thought i posted the results. The exit sensor actuator asm took care of problem. Thanks again.frank
