Have jamming every time after paper exits fuser and is entering delivery assembly. The trailing
edge of paper has not exited fuser and the front edge is just entering delivery unit. If I manually
turn drive gear for delivery unit while trailing edge of paper still in fuser the paper does not
advance but that is probably because to much resistance in fuser rollers holding paper back.
When I turn drive gear manually with paper out of fuser the paper advances thru exit unit.
I was able to see drive gear turning during copy cycle . I will look in Sm to check paper jam
history for sensor actuated in meantime.
I have swapped with new fuser and exit assembly but still have same issue. I cleaned
2 photo sensors below fuser as well. I don't service this series often and would be very grateful for advice. Frank
