xerox 6204
  • Fareed
    • Nov 2016
    • 6
    xerox 6204
    i have a xerox 6204 with a communications error 123-314 i have tried to recover the backup as per PWS that did not work changed control panel did not work any ideas please let me know
  • ahmed abdou
    • Feb 2014
    • 45
    Re: xerox 6204
    if you have bps controller change controller
    • technogeek2009
      • Mar 2011
      • 167
      Re: xerox 6204
      Was there a firmware upgrade prior to this code arising? If so, you may just need to upgrade the UI firmware.
      If you do need to replace the controller, we offer them far less expensively than buying the main board from Xerox. We also offer Accxes controller upgrade kits at nearly the same cost as the controller.
      Carl
      Evergreen Technologies
      cbyrne@goevergreen.net
      • Fareed
        • Nov 2016
        • 6
        Re: xerox 6204
        there was no firmware upgrade power went down and machine came up with 123- 314 error
        • adriansto
          • 2388
          Re: xerox 6204
          Probably corrupt boot files or corrupt partitions on hdd.
          Before to replace controller mainboard you need to do some checkings.
          • VIJAY BALAJI
            • Apr 2012
            • 4
            Re: xerox 6204
            Hi,
            its hard disk problem, change hard disk
            • Service@PRT
              • Oct 2016
              • 181
              Re: xerox 6204
              any one knows how to enter service mode in this machine? i read the manuals.. but cant seem to find how to enter service mode...
              here's the manual for that machine to those who needed.. mmmm i think i cant post download links
              nevermind found it.. xD thanks anyway.. if anyone needs its manual message me and ill give you links of downloads
              Every day of life is a learning process...
              Just make sure you are open in all aspects of comments.
              • marinda
                Re: xerox 6204
                Just keep pressing 0 button on the panel and wait for 5seconds and while keep pressing 0 button press start button and you will enter to the service page.
