Dell 5130 (Xerox Phaser 6700), Lost NVM Values? Error 006-370 with IOT: 00000003h
  • k3wf3w
    • Nov 2016
    • 9
    As the tittle says, I think after messing around with my Dell 5130cdn I have lost the NVM values. I replaced the ESS NVM board, but the machine only starts up to give Error 006-370 and when I hit the Info button for more info it displays IOT Error code 00000003h.
    Any help would be appreciated, thanks!
  • Lance15
    • Jun 2015
    • 1086
    Re: Dell 5130 (Xerox Phaser 6700), Lost NVM Values? Error 006-370 with IOT: 00000003h
    006-370 is a failure of the laser/scanner (ROS).
    FIP1.6 006-370_IOT ROS Failure.pdf
    • k3wf3w
      • Nov 2016
      • 9
      [ATTACH]35056[/ATTACH]
      Thanks for taking interest Lance15, I have cleaned and re-seated the ROS ASSY, and even replaced the ROS ASSY with a known good ASSY, and reconnected every connection on the MCU but the message still returns. Some further info on this machine, the ECC board was replaced, and I think we lost the NVM values on the MCU in the process. Do you know of any procedures to re program the values, and get the MCU and ESS boards back in sync/communication with each other? Also would you be able to send me the service manual for the 5130?
      Thanks!
      • Lance15
        • Jun 2015
        • 1086
        I'm afraid the only procedure is to copy the NVM from the MCU to the ESS. There's no procedure to go the other way. Was it a new ESS that you installed or a used one? What happened that the ESS needed to be replaced? The service manual is 90MB. I don't have a way to get it to you. Doubt E-Mail will work.
        • k3wf3w
          • Nov 2016
          • 9
          It was a used ESS. When I have the old (original) ESS board in the printer, I enter developer/service mode and go to the NVM settings. I am then given the option to load NVM from ESS, but, when I have the new ESS board in the printer, and do the same, I only have the option to save NVM to ESS. By the way, I pulled the battery (I know, I know) :'( on the original ESS and it displays error 116-364.
          Thanks again!
          • Lance15
            • Jun 2015
            • 1086
            • k3wf3w
              • Nov 2016
              • 9
              I just realized something. Did you swap the NVM chip?[ATTACH=CONFIG]35065[/ATTACH]
              No, should I? The NVM chip is volatile though, wouldn't it be essentially the same thing as pulling the battery, like I did on the other board, which caused error 116-364?
              • Lance15
                • Jun 2015
                • 1086
                No. Swap the chip. Until I saw the picture of the board, I didn't realize how similar it was to the 31x0 (3110/3130) boards. You need to swap those chips.
                • k3wf3w
                  • Nov 2016
                  • 9
                  Ok, I swapped the chip. I still get error 006-370 at startup, but in the NVM settings I now have the option to Load NVM from ESS.
                  • Lance15
                    • Jun 2015
                    • 1086
                    Have you done that procedure to load from ESS? If not, give it a shot.
                    • k3wf3w
                      • Nov 2016
                      • 9
                      Yes I did. Still same error during boot. I am sure the laser is fine though. Any more idea's? I noticed an option to Init NVM, in CE mode. I have also been able to get into Firmware Load mode, where it has options to load firmware from USB, Serial, etc. Sorry about the questions and ramblings, just trying to bounce some ideas off you.
                      Thanks!
                      • Lance15
                        • Jun 2015
                        • 1086
                        Hmmm. I'm out of ideas other than the FIP troubleshooting for that error.
                        • tcook
                          • Apr 2013
                          • 37
                          I know this is an old thread, but I came across it in my search for this error. There is a microswitch activated by the back cover. If you try to run the machine with the cover off, it throws this same error - 006-370, IOT 00000003h. Cheat the switch or put the cover on and it's fine.
