xerox 550 Error Code for my finisher 047-320
  • jonathan2016
    • Jun 2025
    Hey guys,
    My finisher has a error code 047-320. If i unplug the finisher the error go's away. is a connection problems?
    How can i fix it?
  • vodo
    • Dec 2016
    • 36
    Re: xerox 550 Error Code for my finisher 047-320
    Originally posted by jonathan2016
    Hey guys,
    How can i fix it?
    If this is an D series finisher, then most likely your PWB, Finisher shorted out already.
    • knightfall
      • Jul 2006
      • 633
      this could be a simple thing as the power cord pulled out on either end of the finisher or it could be 1 of 4 things that went wrong
      first cheat the front door of the finisher and power up the copier and watch the stapler, hole punch and decurler it initializes in that order so check which does not work and check that but if they all check out then its the finisher pwb.
      good luck
      Get your facts first, and then you can distort them as much as you please.
      • jonathan2016
        I think i Need a communication cable for my booklet finisher. I keep getting and error code 047-320.
        I paid i guy to come out and he cleaned it and the error went away. I have frayed communication cable that might be the problem.
        Where can i get one?
        • vodo
          • Dec 2016
          • 36
          [ATTACH=CONFIG]35199[/ATTACH]
          Are you sure cable problem? If so, this is its part number: 962K74860, this cable connect I/F module to D finisher. There is a shorter one, PN 962K03170, this called communication cable. Check with people at Item inc, www.iteminconline.com to see if they have it. Good luck.
          • InterfaceP
            • Jun 2013
            • 488
            PM me, I have quite a few I could get rid of. I ship from Dallas TX
