wc 7435..err 061-370.. how to fix it?
  • lithium898
    • Feb 2016
    • 46
    [Error Code] wc 7435..err 061-370.. how to fix it?
    when i check in Supply Screen all red ..no drum....no fuser...no belt .... no toner !!!
    what happen ???
    i cried cried and cried..
    need some one help me...
    best regard.. many many thanks
  • lithium898
    • Feb 2016
    • 46
    Re: wc 7435..err 061-370.. how to fix it?
    • lithium898
      • Feb 2016
      • 46
      hi all friend..
      i finished this by cleaning the drum unit and lph unit
      and then change the new drum..its all work !!!
      thank you so much ..
      • IGEN93
        • Jul 2018
        • 49
        Originally posted by lithium898
        hi all friend..
        This error is related to lph head connectivity issue , please remove it and re assemble which would give you the resolution and if not resolved yet you have to check lph head by interchanging with other heads .. and replace the same . This error may also cause due to mcu board malfunction.
