D95/D110 Trouble spots.
  • Geo
    • 662
    Hi All
    I am working in an in an environment where I am stuck replacing the consumables in these boxes and making the customer happy.. Unfortunately C.S. from Xerox has been less than adequate and the customer is PISSED.. ... So , For future reference I was wondering what the trouble spots are for these boxes and if I can do anything when replacing the CRU. to possibly catch potential problems ?
    Thanks.
  • InterfaceP
    • Jun 2013
    • 488
    Re: D95/D110 Trouble spots.
    Developer gears tend to stick when releasing to replace the drum unit, also the drum unit sometimes wont engage the switch to detect it's presence.
    • Geo
      • 662
      Do you also know what are some of the most common S.C... One has had multiple 012-255 codes and Xerox apparently is having problems fixing this (Five S.C. in 3 weeks). ...
      Also , does Xerox monitor their copiers for needed consumables and service calls .
      Thanks again for the help.
      • InterfaceP
        • Jun 2013
        • 488
        The inserter (tray 8) on top of the finisher is faulting, not a big deal if your customer isn't using it.
        • Geo
          • 662
          True...Except this copier has only been in service for 3 months...AND this generates a service code on the op panel..
          • InterfaceP
            • Jun 2013
            • 488
            Lift motor fail: CC [013-002] (Up) or [013-003] (Down)
