XEROX C70 FAULT 113-365
  • Piper
    • Apr 2011
    • 77
    [Dead] XEROX C70 FAULT 113-365
    I have a Xerox C70 press giving 113-365 fault. Tried pressing 4, stop & Energy Server buttons
    at power up to reset HDD but machine didn't respond. Also tried pressing Energy Server button
    while powering on to get into software download mode but still machine powers up to 113-365 fault.
  • acfife
    • May 2012
    • 63
    Re: XEROX C70 FAULT 113-365
    The following modes are enabled by pressing a
    combination of keys and turning ON the main power switch, Use these modes when
    the system is unable to enter Diag mode due to troubles or to clear error data
    from HDD spooling.
    Boot Mode Boot Method Function
    Long Boot Diagmode Turn ON the power while pressing the Power Saver
    key and the Start key.
    Automatically determines the condition of each
    Sub-System feature/parts, and the causes for communication errors. It keeps the
    past 3 Long Boot Diagnostic results in the NVM of ESS and IOT when the specific
    diagnostic completes.
    Forced NVM Initialization
    NOTE:
    Inform the customer that the Custom Media Profiles
    and Auditron/Acounting settings and other special, saved UI options will be
    lost. When the process is completed, the message: (Accept all default settings
    to bring the printer to Ready condition) appears.
    key, Stop key and 2 key.
    Initializes the NVM of the configuration range
    (Printer Settings etc.) inside the Controller and starts up.
    Forced LPR Spool Initialization Turn ON the power while pressing the Power Saver
    key, Stop key and 6 key.
    If an error occurs during LPR spooling and the
    system failed to start up after turning the power Off then On, initializes the
    domain that stores the print data by LPR spooling and starts up.
    Forced HDD Format
    NOTE:
    After performing this procedure, you will need to
    re-create the SIQA Folder for the customer. Also, inform the customer that the
    Jobs Saved to Folder and the Scan to Folder will be lost.
    key, Stop key and 4 key.
    This operation resets the HDD to partitions at
    factory settings. Use it as a countermeasure when fault codes 116-331 or 116-354
    occur (see 116-354 RAP or 116-331 RAP).
    Software Download mode Turn ON the power while pressing the Power Saver
    key.
    Power up in Software Download mode when performing
    Firmware Upgrade.
    • Piper
      • Apr 2011
      • 77
      Thanks ACFIFE for your post, but machine is not responding to FORCED HDD FORMAT AND SOFTWARE DOWNLOAD MODE.
      When I press those buttons at power up, machine boots up to a 113-365 fault.
      • Tonersniffer
        • Nov 2012
        • 74
        You lost me at fault code 113-365. Are you sure that is the correct code?
        • Piper
          • Apr 2011
          • 77
          Thanks! You are right. The fault code is 116-365
          • aneudimadera
            • May 2014
            • 30
            Enviado desde mi Nexus 6 mediante Tapatalk
