XEROX 6605 (Error printing)
  • omorales
    • Mar 2015
    • 86
    Hello friends wanted to know if anyone has had this problem.
    When you send a 5-sheet job, print the first 2, and then in the "processing" state, print the next two jobs and the same "processing", until the job is finished. Hence the impression of a simple job the delay is too low.
    Any help is appreciated
  • copier tech
    • 8164
    Re: XEROX 6605 (Error printing)
    Typically any Xerox printing issues is firmware related.
    Check your current firmware levels & update if necessary.
    WC_6605_Firmware_PL4_Customer_Release_Notes.pdf
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      What driver are you using?
      Try another, usually start with the GPD PS one on those wee machines. Turn off advanced features, make sure print processor is Windows. Laptop connected straight into machine as test?
      Looks like you are printing MS Word docs? Quite often have to fit the productivity kit to these devices for slow printing.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
