wc3550 network error
  • tuey
    • Apr 2014
    • 120
    bought a few of these off lease and they all come up with network error-network cable not connected. also says bootp or dhcp problem. i want to return these to non network machines. tried centerware download to correct it there but cant get it downloaded. is there anyway to return these to there original state. thanks-- tuey
  • Daan
    • Mar 2013
    • 60
    Re: wc3550 network error
    This is normal behavior for machines that expect dhcp configurations, which is the factory default iirc.
    You can try a couple things, disable both ipv4 and ipv6, should clear the warning, or disable tcp/ip all together.
    Additionally you could probably just disable the dhcp and enter an address manually, this way you can get back into centre-ware if needed.
    • tuey
      • Apr 2014
      • 120
      thank you daan, i'll try your suggestions. i cannot get centerware to down load from xerox, they say i need a windows program, forget the name, and when i try and download the windows software it fails to load after 30 minutes so i cant get centerware downloaded. i'll let you know - thanks again--tuey
      • Daan
        • Mar 2013
        • 60
        Centreware is the webservice running on the device. Hook it up to a network with dhcp or configure the ip manually on the device. Then you can access the web interface by entering the ip of the printer into your browser.
        • adriansto
          • 2392
          Make a RJ45 loopback = pin1 short with pin3, pin2 short with pin 6.
          Enter RJ45 loopback into machine ethernet port
          • tuey
            • Apr 2014
            • 120
            thats more what i'm looking for, resets the machine back to factory specs ? but i would have to find someone who can make the rj45 loop, never done that. i do not have a network to hook the machine to in my office or warehouse so the centerware solution is out. some of the older xerox you could reset to factory specs from control panel, i tried turning off some of the features in networking and some of the messages went away but still wants that network solution. thank-you for the help
            • tuey
              • Apr 2014
              • 120
              hey adriansto, do you think removing the battery for a while would also set it back to factory ?? thanks--tuey
              • adriansto
                • 2392
                NO
                Why you dont try RJ 45 loopback ?
                Every computer shop can make it
                • tuey
                  • Apr 2014
                  • 120
                  i will try that, i thought i was going to have to go to a data cabler to get something like that made, i know one but a computer shop would be much more convenient. thank you adriansto for the tip, will that reset any xerox machine back to factory?
                  • adriansto
                    • 2392
                    This is not a reset.
                    It fool the machine about the network
                    You need one for every printer.
                    Looks like this
                    • tuey
                      • Apr 2014
                      • 120
                      Thanks pal, really appreciate your efforts.
                      • tuey
                        • Apr 2014
                        • 120
                        for some online 6 for $9 shipped, not gonna mess with the computer shops. thanks again
