Fuser temperature adjustment.
  • Abidqayyum2001
    • May 2017
    • 5
    Is that possible in xerox 5775 to disable one of the fuser lamps or derease their power to save power consumption, or change them with low power lamps to run machine on low power genrater.
    Please help.
  • adriansto
    • 2387
    Re: Fuser temperature adjustmentin xerox 5775
    Better is to replace the fuser lamps with led lamp.
    There will be more light, less heat and very low power consumption.
    And now you can use your copier as noise generator !
    • xtrain
      • Dec 2012
      • 233
      Adrian,
      Good answer. Now he can get a bright fuser but unfused prints. Never heard of LED fuser lamps, but good idea. Do LED,s generate noise?
      • Abidqayyum2001
        • May 2017
        • 5
        Great joke dear, like u.,......
        • ChiChaK
          • May 2017
          • 8
          Re: Fuser temperature adjustment.
          you can reduce the volume of heat if that is what u want? but to change them with some LED lamp sound rediculus
          Une pharmacie fiable viagrasansordonnancefr.com traitement efficace
          • Abidqayyum2001
            • May 2017
            • 5
            Please guide me how to change heat volume?
