Is that possible in xerox 5775 to disable one of the fuser lamps or derease their power to save power consumption, or change them with low power lamps to run machine on low power genrater.
Please help.
Better is to replace the fuser lamps with led lamp.
There will be more light, less heat and very low power consumption.
And now you can use your copier as noise generator !
Adrian,
Good answer. Now he can get a bright fuser but unfused prints. Never heard of LED fuser lamps, but good idea. Do LED,s generate noise?
