Poor Fusing in xerox color 550.
  • Rich0210
    • Dec 2014
    • 2
    [CQ] Poor Fusing in xerox color 550.
    When I am printing in plain or heavy weight paper some times images are not fusing correctly. Particular color means black, or brown and solid Red. when I using Gloss mode the prints are coming correctly, but color is different. I want to use the machine in standard mode, I replaced fuser, 2nd BTR.
    Regards
    vijay
  • davidj7
    • 1107
    Re: Poor Fusing in xerox color 550.
    Print with media as 'coated 2 '
    a machine is only as good as your tech : source:screwtape ; the scary one
    • Rich0210
      • Dec 2014
      • 2
      Thanks for Reply,
      If I printed "coated 2" the problem solved.
      Finally I found the Nip width of fuser is problem, I lubricate inside the film with fuser oil, now the problem solved.
      • Jeroen Steen
        • Sep 2024
        • 6
        I also experience fusing issues on Xerox C60 with the Heavy fuser. How can I adjust the Nip width? I bought the fuser from a Xerox partner, so I assume that the fuser grease was already applied.
