xerox 7132
  • cliffhangers
    • Feb 2010
    • 243
    xerox 7132
    Xerox 7132 displayed 010-333 how can i clair it .and i have forgotten the password.
  • adriansto
    • 2387
    Re: xerox 7132
    Fuser overheat in center
    Be sure the fuser is driven and rotate.
    Also can be a software problem.
    This code must be reset from service menu.
    What machine software ?
    • Mukasa
      • May 2015
      • 178
      Re: xerox 7132
      • To clear this fault, first remove the cause, next clear the value of NVM [744-248] to "0", and then turn the power OFF then ON.
        The flag of NVM [744-248] indicates 0: Normal, 1: NCS-Center abnormal high temperature value, 2: STS-Rear abnormal high temperature value, and 3: NCS and STS high temperature error.
        Check whether foreign substances or paper is wound around the Heat Roll.
        Turn the power OFF, disconnect the Main LVPS connector P/J1 and P/J2.
        At the PWB, measure the resistance between P/J1-3 and P/J2-3/4.
        Is the resistance infinite? Yes No Unanswered
        Replace the Main LVPS ( PL 18.1)
        Replace the following parts in sequence: Replace the Fuser Assembly ( PL 7.1).
        • Check the sw version of the controller sw - reload Software ( GP 7)
        • Fuser Assembly ( PL 7.1)
        • MCU PWB ( PL 18.1)
      • When turning the power OFF, turn OFF the power switch first and then the main power switch.
