xerox wc45 Light pattern spots on copys
  • djacidito
    Please I need help to diagnose what the problem is. I have cleaned the corotron, the drum looks ok. just replaced the fuser, ozone filter, toner cartridge and waste bottle 3 weeks ago. (sorry for my bad English)
  • exCSER
    • Mar 2009
    • 98
    Re: xerox wc45 Light pattern spots on copys
    That looks like high moisture content in the paper. Try other paper that has been wrapped in its ream wrapper.
    • djacidito
      Thanks. I followed your instructions, changed 3 different brands of wrapped paper but the problem continues.
        [QUOTE=djacidito;574725]Please I need help to diagnose what the problem is. I have cleaned the corotron, the drum looks ok. just replaced the fuser, ozone filter, toner cartridge and waste bottle 3 weeks ago. (sorry for my bad English)
        QUOTE]
        looks like a transfer issue.. did you do a half page stop test? how is the image on the drum?
        not sure if this machine has a transfer belt or not...check that or the transfer roller for spots
        • djacidito
          Thank you. I followed your instructions. Transfer roller seems ok, toner looks well distributed. The image on the drum looks like the one printed, light spots of toner in the same places.
            so either the developer or the charge is not getting an even layer....
              did you make sure the laser glass is clean?
              • adriansto
                • 2387
                [ATTACH=CONFIG]37423[/ATTACH]
                You need to change developer material.
                • shaahin
                  • Jun 2017
                  • 26
                  Hi
                  The Developer is low. add developer to fix this problem.
                  The weight of developer and housing is about 4350 g.
                  • chubblies
                    • Jun 2011
                    • 155
                    Check the HV contacts, as it has dumped developer somewhere. Look up "barber pole" on searchlite
