Colorcube 9202 meters?
  • JimHegs
    This Space For Rent
    • 108
    Trying to figure out something, I am looking at a competitors meter request sheet for a Xerox Colorcube 9202 and the sheet indicates three meters CX1, CX2 & CX3. I know that model does tiered billing but is it one mono meter and two tier color, or just the three tier color? can someone explain the Colorcube meter structure and what thresholds they use if possible so I can decipher this meter sheet?
    https://cdn2.project-gc.com/StatBar/...cludeLabcaches
  • prismtech
    • May 2014
    • 199
    Re: Colorcube 9202 meters?
    Google:
    "colorqube customer expectation pdf"
    I'm pretty sure the answer is in there.
    • prismtech
      • May 2014
      • 199
      • JimHegs
        This Space For Rent
        • 108
        Am I reading this correctly? There are three meters?
        Black + very minimal color
        Black + avg color
        Black + a lot of color
        Or is it like Kyocera tiered color where there's a Mono meter and Color1, Color 2 and Color 3 (4 different meters)
        • prismtech
          • May 2014
          • 199
          Black + avg color
          Mono + 2.
          Are you trying to resell your own service contract on a ColorQube? You would rue the day if you did. Machines are almost unuseable new or used.
          • JimHegs
            This Space For Rent
            • 108
            Originally posted by prismtech
            Mono + 2.
            No, I'm helping a sales rep come up with some AMV's on a competitors machine and the customer gave us copies of some old meter requests they had sent back to the incumbent dealer. The math is easy enough but I needed something to reference the CK1, CK2 & CK3 descriptions back to so we can come up with some service pricing on the new equipment proposal so I'll go with Mono, light color, heavier color.
            Thanks for your help.
            BTW, I've NEVER heard anything even slightly positive on the Colorcube products, are they as bad as they sound?
            • prismtech
              • May 2014
              • 199
              Absolute Feces. Print heads are garbage - Drum drive falls apart - Cleaning units fail randomly - Print quality is grainy - Leave streaks on heavy color output - 30 minutes to turn on - UI is garbage - Made cheap with nylon gears etc.
              Only blessing is they are all starting to get replaced at end of lease(s). We literally send them to be shredded for e-waste the second they get picked up.
                YES!
