Xerox Work Center 7556 the transfer belt cleaner wont reset after replacement
  • tonerjockey
    • Apr 2014
    • 573
    Hi Guys,
    I installed the new OEM cleaner unit. but the printout and LCD display that it is spent and doesn't reset. I looked closely at the unit and i see nothing as far as contacts, CRUM chip, or fuse.
    I also went into supplies status and see nothing for resetting it.
    I suppose? that this is a reset done in service mode? and if so, can someone refresh me on entering the service please?
    Xerox used to be "hold 0" while turning on. i think the new ones are Press and hold 0 key for ten seconds then press Start. then the code i think is 6789, or ???
    Any help will be appreciated.
    Thank you, Jim
  • adriansto
    • 2392
    Re: Xerox Work Center 7556 the transfer belt cleaner wont reset after replacement
    Yes that is the procedure for entering diag mode.
    Reset specific HFSI counter.
    • tonerjockey
      • Apr 2014
      • 573
      Thank you adriansto, i appreciate your advice.
      have a very nice day, Jim
