7775 fault 342-330
  • big mike
    • Sep 2012
    • 144
    7775 fault 342-330
    Is there anything in the searchlite for fuser fan failure on the 7775 family? I didn't see it in my pws.
    It works in diagnostics, I cleaned it and reseated the connections. The pws has you replace the fan, iot pwb, mcu pwb and lvps. Any advise is appreciated.
  • adriansto
    • 2384
    Re: 7775 fault 342-330
    Replace fuser ...... - eureka says !
    • big mike
      • Sep 2012
      • 144
      I'll replace the fuser Monday. Thanks for looking it up, Adrian.
      • knightfall
        • Jul 2006
        • 633
        where you able to fix the problem, the fault indicates the fuser fan motor has failed but in fact it just slowed down a little enough to throw the code just replace the fuser fan.
        Get your facts first, and then you can distort them as much as you please.
        • big mike
          • Sep 2012
          • 144
          Thanks, I did fix it...replaced the fan.
