Xerox C 60 Fusing problem
  • pepito17
    • Nov 2008
    • 16
    Hi , I replace my Fusing unit C60 , but can bake a toner well, black and red is detached from the paper. I change with another Fuser and paper and it is the same again
    Re: Xerox C 60 Fusing problem
    not sure what you mean..
    is the toner rubbing off the page after replacing the fusing unit? are the paper type settings set correctly ?
    what about the size also? is it genuine Xerox toner or 3rd party toner ?
    are you getting and errors?
