GSN/Edocs Windows 10
  • fatfingers73
    • Feb 2013
    • 219
    [Misc] GSN/Edocs Windows 10
    All,
    Do windows 10 work with edocs yet?
    IT have upgraded all the laptops!
    Do I need to revert back to 7?
    Many thanks
  • adriansto
    • 2383
    Re: GSN/Edocs Windows 10
    Yes pws version 12 works with Win10 64 bit
    • fatfingers73
      • Feb 2013
      • 219
      Thank you. Is this available on gsn? If not do you know where I can get it?
      • adriansto
        • 2383
        Yes I think it is available but I dont know if the pws tools for machines are also available.
        • fatfingers73
          • Feb 2013
          • 219
          Hi guys,
          I got this set up and working fine.
          But now when I open searchlite I get the attached message
          Any ideas?
          Thank you.
          • danielkhaw
            • Nov 2017
            • 22
            Hi guys,
            Any ideas?
            Thank you.
            Hi, can you share this version of pws?
            • Krunal
              • Oct 2015
              • 64
              Can you share PWS v12. Even I am using win10.
              • adriansto
                • 2383
                Send me mail in the next year !
                • dexters
                  • Jan 2018
                  • 2
                  Can someone share the link where I can download the gsn pws 12
                  Sent from my SM-J730GM using Tapatalk
                  • prashanth
                    Hi guys,
                    Any ideas?
                    Thank you.
                    Dear,
                    I am also facing the same issue. Have you got any solution for this issue? if yes pls let me know. matter most urgent.
                    thank you.
                    • AndreasP
                      Dear all,
                      Do you find any solution of your problem about searchlite because i have the same issue. Any help to solve the problem?
                      Thank you
                      • Sujay
                        • 2
                        Hi guys,
                        Any ideas?
                        Thank you.
                        Hey everyone can you share me pws v12 .
                        My email: aditya9231@gmail.com
                        • Rusty.Harris
                          • Jan 2021
                          • 617
                          If you did the complete edoc install files that is given to you at a class, there is a file called
                          "release12_0_repair.exe" located on your computer in /xerox/xpws/controls.
                          Just about every time Microsoft does an update, it seems to break search lite or some other
                          function of PWS. I just run that and it restores the functionality.
                          • thomfish
                            • Jul 2014
                            • 101
                            Do you mean that after installing edoc rel repair must be run again?
                            • Rusty.Harris
                              • Jan 2021
                              • 617
                              Originally posted by AndreasP
                              Dear all,
                              Thank you
                              Sometimes when all of the "icons" for searchlite etc disappear, for me anyway, it's USUALLY after an MS update on Tuesday/Wednesday.
                              I run the release 12.x repair utility. I've never had it not work, after using that.
