Repeating image on WC7830
  • pe6ohh
    • Nov 2009
    • 17
    Hi there!
    We have a WC7830 wich repeat white colored text at red(Bordo) background as negative black text. Infact it repeat everything white object as negative, inside the bordo background.
    Tomorrow I will post the image here, but if anyone have any idea please help !
  • adriansto
    • 2383
    Re: Repeating image on WC7830
    Originally posted by pe6ohh
    Hi there!
    First check if the fuser rolls have ghosting image on them.
    • pe6ohh
      • Nov 2009
      • 17
      Here is the problem!!!
      I don't think it is fuser problem.
      It decreases on low resolution! BUT colors became different!
      It should be zoomed to see it.
      Drums a 70-90% life, but I changed them.No changes!
      • adriansto
        • 2383
          i'd be looking at a developer charge/grounding issue... a fuser will not cause a negative image .
          • pe6ohh
            • Nov 2009
            • 17
            The distance is 95mm, which is exactly diameter of the drum, but they are changed!
            • adriansto
              • 2383
              Or fuser belt 94 mm lenght.
              Panic stop machine and check image on IBT. Suspect 2nd btr
              Also check unfused image on paper.
              Assuming you use original toners.
